跳转到主内容
Huawei Ascend G7 Display Assembly Replacement
你所需要的
  1. Huawei Ascend G7 Display Assembly Replacement, Remove upper frame casing: 步骤 1 中的图像 1,3 Huawei Ascend G7 Display Assembly Replacement, Remove upper frame casing: 步骤 1 中的图像 2,3 Huawei Ascend G7 Display Assembly Replacement, Remove upper frame casing: 步骤 1 中的图像 3,3
    • Under the top frame there are 3 screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
  2. Huawei Ascend G7 Display Assembly Replacement, Remove the 3 screws: 步骤 2 中的图像 1,1
    • Remove the 3 screws
  3. Huawei Ascend G7 Display Assembly Replacement, Removing lower frame casing: 步骤 3 中的图像 1,3 Huawei Ascend G7 Display Assembly Replacement, Removing lower frame casing: 步骤 3 中的图像 2,3 Huawei Ascend G7 Display Assembly Replacement, Removing lower frame casing: 步骤 3 中的图像 3,3
    • Under the Lower frame there are three screws. The frame is glued. Heat without exaggerating the frame and lever to disengage.
    • This is the same as removing as removing the upper frame casing
  4. Huawei Ascend G7 Display Assembly Replacement, Removing the screws of the lower casing: 步骤 4 中的图像 1,1
    • Removing the 3 screws
  5. Huawei Ascend G7 Display Assembly Replacement, Remove the sim and sd card: 步骤 5 中的图像 1,1
    • Remove the door of Sim
    • Remove the cover of the SD Card.
  6. Huawei Ascend G7 Display Assembly Replacement, Removing the bottom: 步骤 6 中的图像 1,3 Huawei Ascend G7 Display Assembly Replacement, Removing the bottom: 步骤 6 中的图像 2,3 Huawei Ascend G7 Display Assembly Replacement, Removing the bottom: 步骤 6 中的图像 3,3
    • Use a prying tool to pry the display away from the back case.
    • Be careful not to lose the volume buttons and the power button.
  7. Huawei Ascend G7 Display Assembly Replacement: 步骤 7 中的图像 1,1
    • The disassembled smartphone with the aluminum back removed
  8. Huawei Ascend G7 Display Assembly Replacement, Removal Of Battery: 步骤 8 中的图像 1,2 Huawei Ascend G7 Display Assembly Replacement, Removal Of Battery: 步骤 8 中的图像 2,2
    • Disconnect the battery connector.
    • If The battery is stuck, remove it very carefully.
  9. Huawei Ascend G7 Display Assembly Replacement, Disconnect video connector: 步骤 9 中的图像 1,2 Huawei Ascend G7 Display Assembly Replacement, Disconnect video connector: 步骤 9 中的图像 2,2
    • Disconnect the video connector gently.
  10. Huawei Ascend G7 Display Assembly Replacement, Headphone Connector: 步骤 10 中的图像 1,1
    • Gently unplug the headphone connector.
  11. Huawei Ascend G7 Display Assembly Replacement, Remove screw: 步骤 11 中的图像 1,2 Huawei Ascend G7 Display Assembly Replacement, Remove screw: 步骤 11 中的图像 2,2
    • Remove the screw at the bottom.
  12. Huawei Ascend G7 Display Assembly Replacement, Remove the screw: 步骤 12 中的图像 1,2 Huawei Ascend G7 Display Assembly Replacement, Remove the screw: 步骤 12 中的图像 2,2
    • Remove screw from the top
  13. Huawei Ascend G7 Display Assembly Replacement, Remove the screw: 步骤 13 中的图像 1,2 Huawei Ascend G7 Display Assembly Replacement, Remove the screw: 步骤 13 中的图像 2,2
    • Remove the screw next to the video connector.
    • Your almost to the finish line! Just 3 more steps to go.
  14. Huawei Ascend G7 Display Assembly Replacement, Mainboard: 步骤 14 中的图像 1,1
    • Gently rotate outside the motherboard, making sure not to break the little indicated connector
  15. Huawei Ascend G7 Display Assembly Replacement, Connector: 步骤 15 中的图像 1,2 Huawei Ascend G7 Display Assembly Replacement, Connector: 步骤 15 中的图像 2,2
    • If your new display assembly comes with this ribbon cable already installed, disconnect the old one now.
    • If not, separate this part from the old display and transfer it to the new one.
  16. Huawei Ascend G7 Display Assembly Replacement, Removal of the display and the touch screen: 步骤 16 中的图像 1,2 Huawei Ascend G7 Display Assembly Replacement, Removal of the display and the touch screen: 步骤 16 中的图像 2,2
    • Heat the front.
    • Using a plastic tool to separate the lock display / touch screen from the main body.
  17. Huawei Ascend G7 Display Assembly Replacement: 步骤 17 中的图像 1,1
    • You have completed the repair.
结论
36等其他人完成本指南。
Andrea Murinu
于04/07/15注册
948 声望
撰写一个指南
4条评论
donde puedo conseguir el remplazo de la pantalla completa, LCD + touch?
mnemcf95 - 回复
Hi , thanks this info is great . My G7 has a broken touch screen but works fine . I have seen replacement screens and units which include the digiboard ? So do I need to still remove the pcb or just the frame to get to the edge of the touch screen ? is it easy to replace the touch sreen alone ? look forward to your reply . Regards Carl.
carl anthony - 回复
Step 8 - the battery stock very much, I inserted a credit card in between the casing and the battery to detach it. I guess that bending the battery is very dangerous!
Step 15 - This part means the black flat cable with the three buttons ;-)
Step 16 - The new display needed a small film of glue
pacman0 - 回复
Hi, the power on connector on my main board has the plastic clip missing is there a way I can connect them together, they seem too small for soldering.
Andrina - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 21,420
