跳转到主内容
Hp Pavilion dv6-2155dx Optical Drive Replacement
你所需要的
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: 步骤 1 中的图像 1,2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: 步骤 1 中的图像 2,2
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: 步骤 3 中的图像 1,2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: 步骤 3 中的图像 2,2
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: 步骤 4 中的图像 1,2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: 步骤 4 中的图像 2,2
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
结论
2等其他人完成本指南。
Joseph Sanda
于03/10/16注册
522 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 UMass Dartmouth, Team 2-2, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 765
