跳转到主内容
Hp 15-f305dx RAM Replacement
你所需要的
  1. Hp 15-f305dx RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx RAM Replacement: 步骤 2 中的图像 1,1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx RAM Replacement: 步骤 3 中的图像 1,3 Hp 15-f305dx RAM Replacement: 步骤 3 中的图像 2,3 Hp 15-f305dx RAM Replacement: 步骤 3 中的图像 3,3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx RAM Replacement: 步骤 4 中的图像 1,2 Hp 15-f305dx RAM Replacement: 步骤 4 中的图像 2,2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • Remove the two 5mm Phillips #00 screws on the back service cover.
  6. Hp 15-f305dx RAM Replacement: 步骤 6 中的图像 1,2 Hp 15-f305dx RAM Replacement: 步骤 6 中的图像 2,2
    • With the hinge of the laptop screen facing away, remove the panel from the laptop on the near side of you.
  7. Hp 15-f305dx RAM Replacement: 步骤 7 中的图像 1,3 Hp 15-f305dx RAM Replacement: 步骤 7 中的图像 2,3 Hp 15-f305dx RAM Replacement: 步骤 7 中的图像 3,3
    • Press the two locking arms on either side of the RAM card away from each other.
    • When the RAM is free from the locking arms, it should pop up to rest at an angle to the laptop.
    • Remove the RAM card by sliding it out from its port at the same angle at which it rests.
    • During reinstallation, insert the RAM card into the slot at the same angle which it rested earlier, then press it down until the locking arms clasp around it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 627
