本指南有最近更改,您可查看未经巡查的最新版本。
简介
This shows how to change the rear brake pads on cars fitted with the EPB, electronic parking brake. It’s on a Landrover Discovery Sport but is the same method on lots of cars with EPB like VW, Audi etc.
你所需要的
视频概述
Insert wisdom here.
Just follow the video for how to change the rear pads on cars fitted with EPB. This is on a Discovery Sport but applies to others.
2等其他人完成本指南。
4条评论
Excellent tutorial, clear and easy to follow, perfect if you are a novice, looking for the same for the front pads now.
The front pads should be a lot easier because there’s no awkward handbrake to deal with just push back the caliper pistons with a long screwdriver pushing it evenly both sides.
jon -
You can also rewind them using a 12v source rather than taking the cover off (I was worried on my scenic that it might leak if I broke the seal). The cars know when to stop winding as they sence the current increase when the motor jams. We humans can just use our ears. As long as you take the wire off the battery the very second the motor stops you’ll be fine.
Here is me doing mine this weekend.
