跳转到主内容
加入维修社区 - 创建账户
How to wind back the EPB, electronic parking brake, to change rear brake pads
你所需要的
视频概述
    • Insert wisdom here.
    询问修复机器人
    添加评论
结论
Just follow the video for how to change the rear pads on cars fitted with EPB. This is on a Discovery Sport but applies to others.
取消:我没有完成这个指南。
2等其他人完成本指南。
jon
于05/15/16注册
3,318 声望
创作了22篇指南
4指南评论
Excellent tutorial, clear and easy to follow, perfect if you are a novice, looking for the same for the front pads now.
alanmac28@tiscali.co.uk - 回复 分享
The front pads should be a lot easier because there’s no awkward handbrake to deal with just push back the caliper pistons with a long screwdriver pushing it evenly both sides.
jon - 回复 分享
You can also rewind them using a 12v source rather than taking the cover off (I was worried on my scenic that it might leak if I broke the seal). The cars know when to stop winding as they sence the current increase when the motor jams. We humans can just use our ears. As long as you take the wire off the battery the very second the motor stops you’ll be fine.
Here is me doing mine this weekend.
https://youtu.be/kGn7tEjr600
James Taylor - 回复 分享
Discover 150cc bike shocker problem how to repair
Md Shahid - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 40
过去 30 天: 131
总计 42,860
