本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will teach you to how wax your snowboard. Snowboard wax is used to fill small nicks and scrapes and leave the bottom of your board with a slick finish. Waxing your board will allow you to get more speed while tearing it up on the slopes.
你所需要的
Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
Turn the snowboard over so the bottom of the board is facing up.
Set the snowboard down on a stable work surface so that it does not rock or move.
Make sure to clean up the wax shavings when you are done.
2等其他人完成本指南。
一条评论
Had everything autoriding.com I needed to tune and wax my board myself. No more dropping your board off at the shop and having to go back and get in. Can wax the night before and be on the slopes the following morning. Unless you are doing some serious racing then this kit will have everything you need.
