跳转到主内容
How to use a Krone LSA-Plus Punchdown Tool
你所需要的
  1. How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: 步骤 1 中的图像 1,2 How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: 步骤 1 中的图像 2,2
    • There is a difference between LSA and LSA Plus:
    • LSA: The insulation displacement terminals are perpendicular to the cable.
    • LSA Plus: With this technology, the insulation displacement connectors are at an angle of 45° to the cable.
  2. How to use a Krone LSA-Plus Punchdown Tool, Switch the scissors on/off: 步骤 2 中的图像 1,1
    • The Krone tool has integrated scissors that automatically cut the excess when you punch down the wire.
    • To enable or disable the scissors, turn the wheel in the middle of the tool.
  3. How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: 步骤 3 中的图像 1,2 How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: 步骤 3 中的图像 2,2
    • The sensor is a mechanism that only allows the scissors to work if the tool is properly inserted into the LSA slot. You might want to disable it if you want to connect two wires on one contact (requires special contact).
    • To disable the sensor, move the metal bracket at the front of the tool towards the toolhead.
  4. How to use a Krone LSA-Plus Punchdown Tool, Place your cable: 步骤 4 中的图像 1,1
    • Place the cable you want to punch down into the terminal.
  5. How to use a Krone LSA-Plus Punchdown Tool, Punch down: 步骤 5 中的图像 1,2 How to use a Krone LSA-Plus Punchdown Tool, Punch down: 步骤 5 中的图像 2,2
    • Press down on the connector.
    • LSA-Plus is directionally keyed. If your tool doesn't enter into the gap, it might be because you're holding it the wrong way around.
  6. How to use a Krone LSA-Plus Punchdown Tool, Cut the excess: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Flush Cutter
    $29.99
    • If your scissors are off, or you're working in a tight space where the excess left by the tool might be too much you'll have to manually trim the excess.
    • Use electronics sidecutters to trim the excess.
  7. How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 步骤 7 中的图像 1,3 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 步骤 7 中的图像 2,3 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: 步骤 7 中的图像 3,3
    • Press on the tab to release the wire removal hook.
    • Use the hook to pull out the wire you want to remove.
结论
Good luck on your next project!
2等其他人完成本指南。
Sebastian
于08/19/18注册
31,160 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 98
过去 30 天: 452
总计 9,937
