跳转到主内容
加入维修社区 - 创建账户
How to unclog the Keurig Mini B-31 Drain
你所需要的
  1. How to unclog the Keurig Mini B-31 Drain, K-cup holder: 步骤 1 中的图像 1,1
    • Lift up the handle of the Keurig Mini.
    询问修复机器人
    添加评论
  2. How to unclog the Keurig Mini B-31 Drain: 步骤 2 中的图像 1,2 How to unclog the Keurig Mini B-31 Drain: 步骤 2 中的图像 2,2
    • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
    • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
    添加评论
  3. How to unclog the Keurig Mini B-31 Drain: 步骤 3 中的图像 1,2 How to unclog the Keurig Mini B-31 Drain: 步骤 3 中的图像 2,2
    • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
    询问修复机器人
    添加评论
  4. How to unclog the Keurig Mini B-31 Drain: 步骤 4 中的图像 1,1
    • Pull the K-cup holder straight out.
    询问修复机器人
    添加评论
  5. How to unclog the Keurig Mini B-31 Drain, Top: 步骤 5 中的图像 1,3 How to unclog the Keurig Mini B-31 Drain, Top: 步骤 5 中的图像 2,3 How to unclog the Keurig Mini B-31 Drain, Top: 步骤 5 中的图像 3,3
    • Open the top lid of the Keurig.
    • Pull directly outwards on one of the arms that holds the top lid in place. It will take some force to get the arm off the peg. Once one side is off, repeat the process on the second arm.
    添加评论
  6. How to unclog the Keurig Mini B-31 Drain: 步骤 6 中的图像 1,1
    • Lay the Keurig on its back with the water reservoir pointing away from you.
    询问修复机器人
    添加评论
  7. How to unclog the Keurig Mini B-31 Drain: 步骤 7 中的图像 1,1
    • Avoid the top needle as it may puncture your hand.
    • Unscrew the two 9mm #1 Philips screws that hold the top plastic cover in place.
    询问修复机器人
    添加评论
  8. How to unclog the Keurig Mini B-31 Drain: 步骤 8 中的图像 1,1
    • Set the Keurig in an upright position with the front side facing you.
    • Pull the cover off the top of the Keurig. It should come off easily with little force.
    添加评论
  9. How to unclog the Keurig Mini B-31 Drain: 步骤 9 中的图像 1,1
    • Firmly grasp the hose and pull it off of the plastic nozzle.
    添加评论
  10. How to unclog the Keurig Mini B-31 Drain, Top Needle: 步骤 10 中的图像 1,1
    • Unscrew the two 9 mm #1 Philips screws at the top of the device.
    询问修复机器人
    添加评论
  11. How to unclog the Keurig Mini B-31 Drain: 步骤 11 中的图像 1,1
    • Push down lightly on the nozzle that the hose was attached to. The plastic housing along with the needle should pop off without much force.
    添加评论
  12. How to unclog the Keurig Mini B-31 Drain, Arm: 步骤 12 中的图像 1,1
    • With the needle removed, open the device by pulling up on the handle.
    询问修复机器人
    添加评论
  13. How to unclog the Keurig Mini B-31 Drain: 步骤 13 中的图像 1,3 How to unclog the Keurig Mini B-31 Drain: 步骤 13 中的图像 2,3 How to unclog the Keurig Mini B-31 Drain: 步骤 13 中的图像 3,3
    • Push in on one of the arms attached to the K-cup holder plastic housing to remove it from its rails. The arms are identical for both sides so once one side is free repeat the process for the second side.
    • The plastic is flexible and will not snap with the force applied.
    • Once the arms are removed, the configuration should look like the picture. The K-cup holder housing should be separated from the arms.
    添加评论
  14. How to unclog the Keurig Mini B-31 Drain: 步骤 14 中的图像 1,1
    • Use a Phillips #1 screw driver to remove the four 12 mm screws that hold the arm assembly in place.
    询问修复机器人
    添加评论
  15. How to unclog the Keurig Mini B-31 Drain: 步骤 15 中的图像 1,2 How to unclog the Keurig Mini B-31 Drain: 步骤 15 中的图像 2,2
    • Lift up the arm and pull up the handle assembly. It should easily come off.
    • This white tab falls off easily, remove it and set it aside to ensure it is not lost.
    添加评论
  16. How to unclog the Keurig Mini B-31 Drain, How to unclog the Keurig Mini B-31 Drain: 步骤 16 中的图像 1,1
    • Lift up the top arm assembly to get it out of the way. Once it is out of the way, clear out any obstructions in the drain.
    • Use your finger or a slender object to clean the drain. Avoid pushing material further down the drain as that may cause obstructions deeper in the system.
    添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
团队
Cal Poly, Team 17-1, Forte Winter 2014 Cal Poly, Team 17-1, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G1
5 名成员
创作了24篇指南
10指南评论
I wish i would have checked the needle first because that is where mine was clogged...then i wouldn't have had to do all those steps...but the instructions here were very good..thank you...
sue allen - 回复 分享
For me too the problem was that the needle that punctures the pod was clogged. Maybe add to check that first and avoid taking everything apart. Great instructions though.
janpini - 回复 分享
This helped a lot. I used a large syringe. We used to raise birds & had a variety of sizes. Put the syringe on the tube & pulled several times.Seemed to free any clog at the very bottom. Put back together & it's working now.but I notice sprinkles of water as is heats up now. Just need to figure what could be causing this.
lauragriffin76 - 回复 分享
So my keurig was not clogged. BUT. After taking it apart and putting it back together, it works now! #sweetcaffeinatedvictory
godschapis - 回复 分享
This was very helpful. My Keurig is working again. Thanks.
ebelaine52 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 67
总计 57,587
