简介
The following guide will teach you how to examine the wind screen, power cord, jack, and diaphragm.
你所需要的
Remove the windscreen from the top of the microphone.
Once the foam windscreen is removed, examine the windscreen looking for thinning, holes, tears, or discoloration. Any of these issues may be the cause of the sound distortion.
Locate the jack of the microphone and look for: discoloration, rust, breaks in the piece, as well as making sure the jack is not bent or torn from the power cord.
Inspect the cord for splits, breaks, or loose wires. Check the cord from one end to the other, making sure the cord is attached to the microphone.
Another to assessing distortion is to inspect the diaphragm. For further information, see the Diaphragm Examination Guide
Use a Phillips head (#00) screwdriver, to remove the diaphragm and separate the diaphragm from the base of the microphone.
另外一个人完成了本指南。
