跳转到主内容
How to troubleshoot Sony ECM-MS907 sound distortion
你所需要的
  1. How to troubleshoot Sony ECM-MS907 sound distortion, Windscreen Removal and Inspection: 步骤 1 中的图像 1,3 How to troubleshoot Sony ECM-MS907 sound distortion, Windscreen Removal and Inspection: 步骤 1 中的图像 2,3 How to troubleshoot Sony ECM-MS907 sound distortion, Windscreen Removal and Inspection: 步骤 1 中的图像 3,3
    • Remove the windscreen from the top of the microphone.
    • Once the foam windscreen is removed, examine the windscreen looking for thinning, holes, tears, or discoloration. Any of these issues may be the cause of the sound distortion.
  2. How to troubleshoot Sony ECM-MS907 sound distortion, Examine the Jack: 步骤 2 中的图像 1,2 How to troubleshoot Sony ECM-MS907 sound distortion, Examine the Jack: 步骤 2 中的图像 2,2
    • Locate the jack of the microphone and look for: discoloration, rust, breaks in the piece, as well as making sure the jack is not bent or torn from the power cord.
  3. How to troubleshoot Sony ECM-MS907 sound distortion, Examining the Cord: 步骤 3 中的图像 1,2 How to troubleshoot Sony ECM-MS907 sound distortion, Examining the Cord: 步骤 3 中的图像 2,2
    • Inspect the cord for splits, breaks, or loose wires. Check the cord from one end to the other, making sure the cord is attached to the microphone.
  4. How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 4 中的图像 1,3 How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 4 中的图像 2,3 How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 4 中的图像 3,3
    • To check the cord further by unscrewing the bottom piece of the microphone from the top. Rotate clockwise to unscrew the bottom and examine.
  5. How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 5 中的图像 1,3 How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 5 中的图像 2,3 How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 5 中的图像 3,3
    • Another to assessing distortion is to inspect the diaphragm. For further information, see the Diaphragm Examination Guide
    • Use a Phillips head (#00) screwdriver, to remove the diaphragm and separate the diaphragm from the base of the microphone.
  6. How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 6 中的图像 1,3 How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 6 中的图像 2,3 How to troubleshoot Sony ECM-MS907 sound distortion: 步骤 6 中的图像 3,3
    • Inspect the diaphragm checking to see if the piece is dirty, bent, or has holes. If it is bent or has holes, it may need to be replaced.
    • If the diaphragm is dirty, clean it with a dry towel or cotton swab by gently brushing dirt and/or rust off the piece.
结论
另外一个人完成了本指南。
Justin Lewis
于01/23/14注册
242 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 938
