跳转到主内容
How to strip Cat.7 S/FTP PiMF Ethernet Cable
你所需要的
  1. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Clean up the ends: 步骤 1 中的图像 1,2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Clean up the ends: 步骤 1 中的图像 2,2
    • Use wire cutters to make a clean cut on the end of the cable you want to strip.
  2. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the mantle: 步骤 2 中的图像 1,2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the mantle: 步骤 2 中的图像 2,2
    • Grip the cable with a stripping tool for communication cables and twist it to cut the mantle.
    • Pull off the mantle.
    • It depends on what you want to do with the wire, but usually stripping off about 5cm is a pretty good starting point.
  3. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: 步骤 3 中的图像 1,3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: 步骤 3 中的图像 2,3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Pull back the braided shield: 步骤 3 中的图像 3,3
    • Pull back the grounding mesh and twist it around the first cm of still insulated cable.
    • You can leave the excess, but if you want to cut it, make sure to leave at least about 1cm.
  4. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Spread the twisted pairs: 步骤 4 中的图像 1,1
    • Spread out the twisted pairs to make them easier to work with.
  5. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Remove the shielding: 步骤 5 中的图像 1,2 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Remove the shielding: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Flush Cutter
    $29.99
    • Unwrap the shielding a bit and nick it at the base with some electronics side cutters.
    • If you will wire this cable in a terminal block instead of a Keystone or crimping on a connector, you should just remove the minimum amount of shielding needed to properly punch down the connection.
    • Make sure to not damage the delicate insulation of the individual wires.
    • Rip off the shielding.
    • Repeat for all four twisted pairs.
  6. How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): 步骤 6 中的图像 1,3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): 步骤 6 中的图像 2,3 How to strip Cat.7 S/FTP PiMF Ethernet Cable, Strip the wire (optional): 步骤 6 中的图像 3,3
    • Stripping the wire itself is optional, depending on what you want to do with it. P. ex. if you are going to punch it down into an LSA Plus block, you don't need to strip the wire.
    • Grip the wire with the 0.3 mm notch and pull off the insulation or use automatic wire strippers.
    • Stripping off 1cm is usually enough.
结论
Good luck on your next project!
2等其他人完成本指南。
Sebastian
于08/19/18注册
31,160 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 90
总计 2,729
