跳转到主内容
How to stop bicycle brakes from squeaking
你所需要的
  1. How to stop bicycle brakes from squeaking, How to stop bicycle brakes from squeaking: 步骤 1 中的图像 1,1
    • Loosen the brake pads from the calipers using a 10mm wrench.
    • You will need to repeat this step for the second brake pad located on the other side of the wheel.
  2. How to stop bicycle brakes from squeaking: 步骤 2 中的图像 1,1
    • Remove the brake pads from the calipers.
  3. How to stop bicycle brakes from squeaking: 步骤 3 中的图像 1,1
    • Clean the surface of the brake pad with a cloth or water if necessary.
    • The surface of the rims where the brake pads make contact may also need to be cleaned.
  4. How to stop bicycle brakes from squeaking: 步骤 4 中的图像 1,1
    • Reattach the brake pads to the calipers and tighten them with the 10mm wrench so that the leading edge of the brake sits closer to the rim than the rear edge.
  5. How to stop bicycle brakes from squeaking: 步骤 5 中的图像 1,1
    • Check the brake cable and make sure that it is still connected and secured to the brake calipers.
  6. How to stop bicycle brakes from squeaking: 步骤 6 中的图像 1,1
    • Test the brake to ensure that it functions properly before riding the bike.
结论
Kevin Colon
于02/08/18注册
160 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 1,983
