跳转到主内容
How to rewire a Nostalgia Electrics PCM805
你所需要的
  1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: 步骤 1 中的图像 1,2 How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: 步骤 1 中的图像 2,2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  2. How to rewire a Nostalgia Electrics PCM805: 步骤 2 中的图像 1,3 How to rewire a Nostalgia Electrics PCM805: 步骤 2 中的图像 2,3 How to rewire a Nostalgia Electrics PCM805: 步骤 2 中的图像 3,3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  3. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: 步骤 3 中的图像 1,2 How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: 步骤 3 中的图像 2,2
    • Using the wire stripper, remove 1/2 inch of the wire insulation at the end of each wire to expose the bare wire for re-connection.
  4. How to rewire a Nostalgia Electrics PCM805: 步骤 4 中的图像 1,3 How to rewire a Nostalgia Electrics PCM805: 步骤 4 中的图像 2,3 How to rewire a Nostalgia Electrics PCM805: 步骤 4 中的图像 3,3
    • Twist the exposed ends of the wires so that they stay together.
    • Push the wire cap onto the exposed ends while holding the wires and twist in a clock-wise direction until it is tight.
    • Repeat this process for both bundles of wires.
    • Do not attempt to power on the device without the wire caps on or mix wires between the bundles.
终点
Carlton
于01/13/15注册
672 声望
创作了5篇指南
团队
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G5
5 名成员
创作了8篇指南
1指南评论
DO NOT TRY THIS..it broke my machine TO NOT TRY THIS
Izzy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 862
