跳转到主内容
How to restring and tune a Paloma Shahi Baaja
  1. How to restring and tune a Paloma Shahi Baaja, How to restring and tune a Paloma Shahi Baaja: 步骤 1 中的图像 1,1
    • Both melody strings can be tuned by using the same process. Once one string has been tuned, simply repeat these steps to tune the other string.
  2. How to restring and tune a Paloma Shahi Baaja: 步骤 2 中的图像 1,1
    • Carefully, turn the tuning peg counterclockwise to tighten the string. Tightening the string will raise the pitch of the note.
    • If the pitch gets too high, turn the tuning peg slowly clockwise to loosen the string. Loosening the string will lower the pitch of the note.
  3. How to restring and tune a Paloma Shahi Baaja: 步骤 3 中的图像 1,1
    • Locate the ends of the strings. These can be found at the base of the instrument where there are metal circles that hold the strings in place.
    • Slowly, start turning the tuning peg clockwise to loosen the string.
  4. How to restring and tune a Paloma Shahi Baaja: 步骤 4 中的图像 1,1
    • Once the string has been completely loosened, pull it through the slit of the back piece.
    • Pay careful attention to how the string comes out.
  5. How to restring and tune a Paloma Shahi Baaja: 步骤 5 中的图像 1,2 How to restring and tune a Paloma Shahi Baaja: 步骤 5 中的图像 2,2
    • Take the new string and run it back underneath the metal bridge cover, just as it was removed in the previous step.
    • Make sure the string lays within the notch of the bridge.
  6. How to restring and tune a Paloma Shahi Baaja: 步骤 6 中的图像 1,1
    • Once the string is pulled closer to the tuning peg, it will pass over another bridge piece. This is called the nut.
    • Make sure that the string fits into the corresponding notch of the nut.
  7. How to restring and tune a Paloma Shahi Baaja: 步骤 7 中的图像 1,1
    • Run the string through the tuner hole until half an inch of the string is protruding on the other side of the peg.
  8. How to restring and tune a Paloma Shahi Baaja: 步骤 8 中的图像 1,1
    • Start to turn the tuning peg counter clockwise, keeping the half inch piece of string on top of the string which is being wound around the tuning peg.
    • This will stop the string from jumping over the tuner, making a tighter string.
    • Make sure that the string is laying on top of the tuner as seen in the picture.
    • Make sure that the string is still resting in both of the bridge notches (steps 5 & 6) as you tighten it.
  9. How to restring and tune a Paloma Shahi Baaja: 步骤 9 中的图像 1,1
    • Tuning- The strings should be laying over the top of the tuning pegs as seen in picture 2.
    • You may use a guitar tuner to tune your strings.
  10. How to restring and tune a Paloma Shahi Baaja, Tuning a Flat String: 步骤 10 中的图像 1,1
    • Pluck the string to play a note.
    • The picture shows what a tuner would look like if the string played a C note that is flat.
    • Everything that falls to the left of the zero is flat. Everything that falls to the right of the zero is sharp.
    • Turn the tuning peg counterclockwise to raise the pitch of the string.
    • Continue to raise the pitch as necessary. If your string becomes too sharp, proceed to Step 12.
  11. How to restring and tune a Paloma Shahi Baaja: 步骤 11 中的图像 1,1
    • Pluck the note again to re-evaluate the pitch.
    • The picture shows that the pitch is still flat, but not as flat as the picture in Step 10.
    • Tighten the string until the needle on the tuner either reaches the zero or passes it.
  12. How to restring and tune a Paloma Shahi Baaja, Tuning a Sharp String: 步骤 12 中的图像 1,1
    • The picture to the right shows a pitch that is sharp.
    • Turn the tuning peg clockwise to loosen the string.
  13. How to restring and tune a Paloma Shahi Baaja: 步骤 13 中的图像 1,1
    • Continue to tighten or loosen the string until the needle falls exactly on the zero mark.
  14. How to restring and tune a Paloma Shahi Baaja: 步骤 14 中的图像 1,1
    • To tune the other melody string, simply repeat this process.
结论
Follow the steps, and your shahi baaja will be in tune.
Eric Ivy
于06/02/17注册
101 声望
撰写一个指南
3指南评论
You explain how a tuner works, but you don’t say in which note should each of the 15 strings should be tuned, could you please add it to the guide?
Thanks.
Alex3 - 回复
I Just brought a Paloma just about few weeks back. Even i have the same question. how about the 15 strings?? Please add this info. Its important. If these strings are out of , the “Pickup” pulls up that sound also. thanks in advance….Mohan.
Mohan Achar - 回复
Tune the Paloma Shahi Baaja to C. The 2 melody strings tune to G. The third white key from the bottom is your tonic C. The 3 strings are the drones; tune these to C-G-C.  The 10 string representing the swarmandal can be tuned from low to high: C-C-C-Eb-F-G-G-Bb-C-C.  You may find many tunings that work.
Jared drummer - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 28
总计 1,474
