跳转到主内容
加入维修社区 - 创建账户
How to restore UV Damaged Headlights
你所需要的
  1. How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: 步骤 1 中的图像 1,3 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: 步骤 1 中的图像 2,3 How to restore UV Damaged Headlights, How to restore UV Damaged Headlights: 步骤 1 中的图像 3,3
    • In a shaded area, apply masking tape on the outer edges of the headlight assembly.
  2. How to restore UV Damaged Headlights: 步骤 2 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 2 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 2 中的图像 3,3
    • Use the spray bottle of soapy water to wet the 800-grit sandpaper.
    • Spray the sandpaper liberally and make sure it is completely wet.
  3. How to restore UV Damaged Headlights: 步骤 3 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 3 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 3 中的图像 3,3
    • Spray the headlight with soapy water and sand the headlight's surface.
    • Continuously spray the headlight and the sandpaper with water. The surface must stay wet during sanding.
    • Sand the headlight in a circular motion throughout this step.
    • Stop sanding when the entire headlight appears foggy.
  4. How to restore UV Damaged Headlights: 步骤 4 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 4 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 4 中的图像 3,3
    • Spray the 2000-grit sandpaper with soapy water and ensure it is completely wet.
    • Sand the headlight in a circular motion while maintaining the surface wet with soapy water.
    • Stop sanding when the headlight appears slightly less cloudy (than in the previous step).
  5. How to restore UV Damaged Headlights: 步骤 5 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 5 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Lightly wet a small section of a clean microfiber cloth with 70% isopropyl alcohol.
    • Rub down the entire headlight surface with the microfiber cloth.
  6. How to restore UV Damaged Headlights: 步骤 6 中的图像 1,2 How to restore UV Damaged Headlights: 步骤 6 中的图像 2,2
    • Carefully peel off the old masking tape.
    • Use newspaper to cover the car's body using masking tape to hold it down.
    • Shield any gaps and use newspapers at least a foot long.
    • The newspaper will protect the car from overspray in the next step.
  7. How to restore UV Damaged Headlights: 步骤 7 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 7 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 7 中的图像 3,3
    • Use a clear coat to spray the headlight.
    • Follow the clear coat manufacturer's instructions for spraying distance, number of coats, and drying time.
    • Apply the clear coat in well-ventilated conditions.
  8. How to restore UV Damaged Headlights: 步骤 8 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 8 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 8 中的图像 3,3
    • Apply a small amount of compound to a clean microfiber applicator pad.
    • Dap the headlight's surface with the compound.
    • Work the compound into the headlight.
    • Use heavy pressure and rub in a circular motion when working the compound into the headlight.
  9. How to restore UV Damaged Headlights: 步骤 9 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 9 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 9 中的图像 3,3
    • Wipe the headlight with a clean microfiber cloth.
    • Apply a small amount of polish onto a new, clean microfiber applicator pad.
    • Dap the polish onto the headlight, then work the polish onto the headlight.
  10. How to restore UV Damaged Headlights: 步骤 10 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 10 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 10 中的图像 3,3
    • Wipe the headlight with the clean side of a microfiber cloth.
    • Use a microfiber cloth to scoop about a quarter-sized amount of wax.
    • Rub the wax into the headlight with medium pressure and in a circular motion.
    • Continue rubbing until there is no more visible wax.
  11. How to restore UV Damaged Headlights: 步骤 11 中的图像 1,3 How to restore UV Damaged Headlights: 步骤 11 中的图像 2,3 How to restore UV Damaged Headlights: 步骤 11 中的图像 3,3
    • Wipe the headlight with a clean side of microfiber cloth.
    • Carefully remove the newspaper and masking tape.
    • Enjoy the clear road with your newly restored headlights!
结论
4等其他人完成本指南。
1指南评论
Greetings and thank you for such a comprehensive guide on cleaning the head lights of a vehicle
Peter Jafta - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 99
总计 2,064
