跳转到主内容
How to reset the print counter to zero
  1. How to reset the print counter to zero, Find the electronic contact card: 步骤 1 中的图像 1,1
    • On the side of the cartridge is a small electronic contact card with 4 contacts.
    • For those who are interested in transposing on other models, at the back of the contact card point is a EEPROM BR24L01A-W type memory.
  2. How to reset the print counter to zero, Prepare the Arduino: 步骤 2 中的图像 1,2 How to reset the print counter to zero, Prepare the Arduino: 步骤 2 中的图像 2,2
    • The EDPROM can be reprogrammed thanks to an Arduino UNO card, for instance.
    • Prepare an Arduino UNO card with the following pins:
    • Pin 1 (SCL) connected to A5
    • Pin 2 (SDA) connected to A4
    • Pin 3 (5V) connected to the 5V port on the Arduino card
    • Pin 4 (GND) connected to GND on the Arduino card.
  3. How to reset the print counter to zero, Programming: 步骤 3 中的图像 1,1
    • Download the ICI program file
    • Start Arduino and open the .ino file
    • Upload the program to the Arduino Uno board
    • Launch the serial monitor via the button at the top right
    • Make contact on the cartridge card. The 4 contacts need to work well at the same time
    • Follow the instructions to reprogram the memory according to the correct color (Black, Cyan, Magenta, Yellow)
结论
By reinstalling the cartridge in the printer, it identifies it as 100% full!
另外一个人完成了本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
MattMich
于02/08/16注册
31 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 918
