简介
Mac笔记本电脑不能正常启动?你心爱的Mac发生了奇怪的事情?重置你的SMC、PRAM和NVRAM可能会有帮助!
如果你的MacBook Pro 2018型号有T2芯片,请看这个指南,因为该型号的步骤不同。
选择苹果菜单>关闭。
在你的Mac关机后,按下内置键盘左侧的Shift-Control-Option键,然后同时按下电源键。按住这些键和电源按钮10秒钟。如果你有一台带Touch ID的MacBook Pro,Touch ID按钮也是电源按钮。
松开所有按键。再按一次电源键,打开你的Mac。
关闭你的Mac的电源。
移除电池。
如果你不确定如何拆除你的Mac电池,请到这个链接,选择你的Mac的品牌和型号。
一旦你取出了电池,按住电源按钮5秒钟。
松开电源按钮。重新安装电池。
像打开Mac一样再次按下电源按钮。
关掉电脑。
按下电源按钮。
在灰色屏幕显示之前,同时按住Command + Option + P + R键。
按住这些键,直到MacBook重新启动,然后你会听到启动声音。
松开这些按键。
如果这些重置对你的Mac没有帮助,请到Answers论坛(如果你还没有去过那里),向我们友好的社区询问下一步的措施。
28等其他人完成本指南。
由衷感谢以下译者:
100%
我叫小灰宇_Alex-Z正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
Got a 2012 Macbook Pro. Was running GIMP with a couple Browsers open and Word. Gimp crashed twice and I had to restart it. I saved a GIMP file to a png. Placing one png over another, it all froze: Cursor and all not moving. Pressed Cntrl/alt/shift, etc and it closed the the first application open, in layered fashion, but until I got to the last finder window, it kept opening. Shut down completely. Start up took about 2 minutes (usually 37 seconds. Has 2TB SSD and 10GB memory). Was super fast, until today).
When I click on any file or program, it hesitates for a second, then opens as if it’s on a delay, with an odd trace of lighting or movement tracks. Tried the finder “search” and it isnt’ recognizing anything, like it’s not accessing directories, etc. Had to open Applications, to get DiskUtility and run it. Nothing changed. There is a thin grey line that appears to run horizontally through the middle of the “search box”. What’s up???
