跳转到主内容
修复你的物品
维修的权力
商店
简介
Mac Laptop not booting up properly? Strange things happening to your beloved Mac? Resetting your SMC, PRAM, and NVRAM might help!
If you have a MacBook Pro 2018 Model with a T2 Chip head over to this guide as the steps are different for that model.
  1. If your Mac has a removable battery, skip  this step and go to step 2.
    • If your Mac has a removable battery, skip this step and go to step 2.
    • Choose Apple menu > Shut Down.
    • After your Mac shuts down, press Shift-Control-Option on the left side of the built-in keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds. If you have a MacBook Pro with Touch ID, the Touch ID button is also the power button.
    • Release all keys. Press the power button again to turn on your Mac.
  2. Power down your Mac.
    • Power down your Mac.
    • Remove the battery.
    • If you are unsure how to remove your Mac's battery, head on over to this linkand select your Mac's make and model.
    • Once you have removed the battery, press and hold the power button for 5 seconds.
    • Release the power button. Reinstall the battery.
    • Press the power button again as you would to turn on the Mac.
  3. Shut down the computer
    • Shut down the computer
    • Press the Power button
    • Before the grey color screen is shown, press and hold Command + Option + P + R keys simultaneously.
    • Hold down these keys until the MacBook restarts and then you will hear the startup sound.
    • Release the keys.
    • Once you have reset PRAM/NVRAM, keep in mind that settings like disk caches, volume, time, keyboard and mouse preferences, will also be reset.
    I got macbook air early 2015. And it doesnt turn on. I tried to perform a SMC reset but when i press the buttons, macbook just stops charging. So i am still unable to turn my macbook on. What should i do next?
    ritsetivid - 回复
结论
If these reset did not help you with your Mac, head on over to the Answers Forum (if you have not already been there) and ask our friendly community for the next steps.
14等其他人完成本指南。
Aaron Cooke
于2018年08月28日注册
22,570 信誉积分
创作了21篇指南
团队
NIWOTech NIWOTech 的会员
Community
0 名成员
创作了0篇指南
Got a 2012 Macbook Pro. Was running GIMP with a couple Browsers open and Word. Gimp crashed twice and I had to restart it. I saved a GIMP file to a png. Placing one png over another, it all froze: Cursor and all not moving. Pressed Cntrl/alt/shift, etc and it closed the the first application open, in layered fashion, but until I got to the last finder window, it kept opening. Shut down completely. Start up took about 2 minutes (usually 37 seconds. Has 2TB SSD and 10GB memory). Was super fast, until today).
When I click on any file or program, it hesitates for a second, then opens as if it’s on a delay, with an odd trace of lighting or movement tracks. Tried the finder “search” and it isnt’ recognizing anything, like it’s not accessing directories, etc. Had to open Applications, to get DiskUtility and run it. Nothing changed. There is a thin grey line that appears to run horizontally through the middle of the “search box”. What’s up???
Fish Outta Water - 回复
添加评论
浏览统计数据:
过去的24小时: 60
过去的7天: 412
过去的30天: 2,213
总计 32,527
