简介
If you forget your Flipper Zero PIN, the only way to regain access to your device is to perform a factory reset, which will erase all data on the device, including the existing PIN. After the factory reset, you'll be able to set a new PIN and regain access to your device.
The dolphin's level, settings, and information about paired devices will be erased. Data saved on the microSD card will not be lost.
Try to remember your PIN next time!
4等其他人完成本指南。
4指南评论
You have to wait until the timer ends and it asks for the passcode again. Only THEN can you perform the steps. I just successfully did so after experiencing the same issue as you.
If i do the same steps my flipper says: Flipper crashed and was rebooted HardFault. What can i do? is there maybe another way ?
i got the pin for the flipper : Left Up Right Down = press Insert
