简介
A failed radiant ring stops you cooking and often leads people to discard an otherwise healthy stove. By fitting a new heating element, you can restore full performance, avoid waste, and keep your appliance in service. This guide shows a safe DIY method for a standard glass ceramic hob.
If you're not sure whether the heating element is the problem, head over to our Stove Troubleshooting page to help diagnose the issue first.
你所需要的
步骤 2 Remove the hob from the worktop
Undo the four mounting screws on the underside of the worktop, two on each side.
Lift the hob vertically out of the cut‑out once all screws are removed.
步骤 3 Protect the glass surface
Lay a soft towel on the bench and flip the hob so the glass rests safely on it.
步骤 4 Locate the faulty heating element
Confirm which cooking zone no longer heats and locate its matching element under the glass.
步骤 6 Disconnect the element wiring
Pull the spade terminals off the heating element one by one using insulated pliers.
步骤 7 Release the mounting hardware
Undo the single central screw holding the distance spacer to the chassis.
Press the spring clips and lift the heating element clear of its seat.
步骤 10 Install the new element
Set the new element into the housing, aligning its tabs with the cut‑outs.
Press down until the spring clips engage and the element sits flush.
Insert and tighten the mounting screw to secure the spacer.
步骤 11 Reconnect the wiring
Reconnect each wire to its original terminal following your photo reference.
步骤 12 Re‑install the hob
Rotate the hob upright, guide the cable back through the worktop and lower the unit into the cut‑out.
Refit the four mounting screws and tighten evenly.
Reconnect the power plug and test the repaired cooking zone.
Your hob should now heat evenly again. Monitor the repaired zone for a few minutes; any smells or unusual noises mean power off immediately and re‑check connections. Retain all photos and notes for future maintenance and dispose of the old element at an authorised e‑waste collection point.
另外一个人完成了本指南。
