简介
If your washing machine trips the breaker, gives off a burnt smell, or just won’t power on, the culprit could be the RSO filter, also called an input interference filter. This small but important component prevents electrical noise and surges from damaging your appliance.
Fortunately, it’s easy to replace, inexpensive, and can bring your washer back to life without calling a technician.
你所需要的
步骤 2 Recognise symptoms and warranty considerations
Breaker trips, burnt smells, or popping noises often signal a failed RSO filter.
步骤 3 Locate the RSO filter
Look near the power entry point for a small rectangular or cylindrical unit marked with mains voltage ratings.
On some older machines the filter sits behind the front panel and is secured by a 13 mm nut.
Many newer models mount the filter under the removed top cover beside the power cord entry.
步骤 4 Remove the top cover
Undo the two or three screws on the machine’s back edge with a screwdriver.
Slide the cover backward and lift it off to expose the filter compartment.
步骤 5 Photograph wiring orientation
Use a camera or smartphone to capture clear images of every wire connected to the RSO filter.
Two green‑yellow earth wires attach to the metal tabs of the filter and must return to the same positions.
步骤 6 Disconnect wiring
Grip each spade connector and pull it straight off the filter tabs to free phase, neutral, and earth leads.
步骤 7 Remove the faulty filter
Undo the two screws securing the filter bracket using a screwdriver or wrench.
Lift the filter upward to clear the plastic locating clips and withdraw it from the appliance.
Check the removed filter for scorch marks, cracks, or bulging metal which confirm internal failure.
步骤 8 Install the replacement filter
Seat the new filter into the bracket so all four plastic lugs fully engage.
Tighten both mounting screws until snug without overtightening.
步骤 9 Reconnect wiring
Attach both earth wires to the filter’s ground tabs.
Push the harness connector onto the output terminals until fully seated.
Fit incoming phase and neutral wires onto their original straight terminals.
步骤 10 Reassemble and test
Replace the washing machine’s top cover and secure it with the rear screws.
Reconnect the power cord and run a short rinse cycle to verify the breaker no longer trips and no smell is present.
With the new RSO filter in place, your washer should operate quietly and without tripping breakers. Keep the photos you took for future reference, always disconnect power before further work, and consult an authorised service centre if unusual symptoms return.
You’ve successfully replaced the RSO filter. If your washer powers on and runs normally again—congrats! This tiny part often solves big electrical issues.
If your machine still smells burnt, won’t turn on, or trips the FID switch again, take a second look at the filter—burn marks, bulging, or a “pop” sound are all signs of failure. Even if it looks okay, a faulty RSO filter may be the hidden culprit.
另外一个人完成了本指南。
