简介
This guide will teach you how to replace a broken or damaged charging port in your Nintendo 2DS
你所需要的
视频概述
Hold the side panels of the device's case with your fingers and pull outward to remove them.
There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
Hold the top panel with your fingers and pull away from the device to remove it.
Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
Holding the motherboard on either side, lift to remove it.
To reassemble your device, follow these instructions in reverse order, starting at step 10
2等其他人完成本指南。
