跳转到主内容
How to replace or tighten the inner screws of an FC fan
你所需要的
  1. How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: 步骤 1 中的图像 1,3 How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: 步骤 1 中的图像 2,3 How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: 步骤 1 中的图像 3,3
    • Ensure the device is powered off completely and disconnected from any external power source.
    • Unlatch the four hinges located around the edge of the fan cage by gently pulling them away from the fan cage.
  2. How to replace or tighten the inner screws of an FC fan: 步骤 2 中的图像 1,2 How to replace or tighten the inner screws of an FC fan: 步骤 2 中的图像 2,2
    • Locate, loosen and remove the screw that is found at the bottom of the cage using a Phillips #1 screwdriver.
  3. How to replace or tighten the inner screws of an FC fan: 步骤 3 中的图像 1,1
    • Remove the front half of the cage from the fan by wiggling gently it until it disconnects from the rest of the fan.
  4. How to replace or tighten the inner screws of an FC fan: 步骤 4 中的图像 1,3 How to replace or tighten the inner screws of an FC fan: 步骤 4 中的图像 2,3 How to replace or tighten the inner screws of an FC fan: 步骤 4 中的图像 3,3
    • Twist the now exposed central fan cap clockwise to remove it from the fan blades.
  5. How to replace or tighten the inner screws of an FC fan: 步骤 5 中的图像 1,2 How to replace or tighten the inner screws of an FC fan: 步骤 5 中的图像 2,2
    • Twist the fan blades clockwise to remove them from the central axel.
  6. How to replace or tighten the inner screws of an FC fan: 步骤 6 中的图像 1,3 How to replace or tighten the inner screws of an FC fan: 步骤 6 中的图像 2,3 How to replace or tighten the inner screws of an FC fan: 步骤 6 中的图像 3,3
    • Remove or tighten the two inner screws as necessary, making sure the screws are tightened only until you are met with slight resistance when reassembling.
结论
另外一个人完成了本指南。
Zain Andani
于09/12/23注册
133 声望
撰写一个指南
团队
York University, Team 2-2, O'Regan Fall 2023 York University, Team 2-2, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S2G2
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 120
