跳转到主内容
加入维修社区 - 创建账户
How to replace a broken towel hook on drywall
你所需要的
  1. How to replace a broken towel hook on drywall, Towel Hook: 步骤 1 中的图像 1,2 How to replace a broken towel hook on drywall, Towel Hook: 步骤 1 中的图像 2,2
    • Using your Phillips screwdriver, remove both screws that are keeping your current (broken) drywall hook in place.
    • Make sure you remove both screws evenly, to avoid bending and damaging the screws and the drywall around it.
    询问修复机器人
    添加评论
  2. How to replace a broken towel hook on drywall: 步骤 2 中的图像 1,1
    • After removing both screws, remove the plastic anchor screws from the drywall.
    • It will leave a big hole, but we will fix that!
    询问修复机器人
    添加评论
  3. How to replace a broken towel hook on drywall: 步骤 3 中的图像 1,3 How to replace a broken towel hook on drywall: 步骤 3 中的图像 2,3 How to replace a broken towel hook on drywall: 步骤 3 中的图像 3,3
    • After removing the anchor screws, take your spatula and press it flush with the wall. Remove debris from the drywall to make the wall flat.
    询问修复机器人
    添加评论
  4. How to replace a broken towel hook on drywall: 步骤 4 中的图像 1,2 How to replace a broken towel hook on drywall: 步骤 4 中的图像 2,2
    • Take some patching and with your spatula, apply it on and around the holes in order to fill it up to the surface of the wall.
    询问修复机器人
    添加评论
  5. How to replace a broken towel hook on drywall: 步骤 5 中的图像 1,2 How to replace a broken towel hook on drywall: 步骤 5 中的图像 2,2
    • Select a new location for your new towel hook and, with one of the screws, mark the spot where you'll drill the holes.
    • Use your screwdriver to tap the two new locations, to make it easier to screw the anchors onto the wall.
    询问修复机器人
    添加评论
  6. How to replace a broken towel hook on drywall: 步骤 6 中的图像 1,2 How to replace a broken towel hook on drywall: 步骤 6 中的图像 2,2
    • Take your new anchor screws and start drilling on your marked holes.
    • Keep screwing them into the drywall until they're flush with the wall.
    • Don't drill too far, or else it will damage the drywall and the towel hook will be uneven!
    询问修复机器人
    添加评论
  7. How to replace a broken towel hook on drywall: 步骤 7 中的图像 1,3 How to replace a broken towel hook on drywall: 步骤 7 中的图像 2,3 How to replace a broken towel hook on drywall: 步骤 7 中的图像 3,3
    • Line up your new towel hook with the holes where the anchors are located.
    • Take your screws and start screwing them in manually so they stay in place.
    询问修复机器人
    添加评论
  8. How to replace a broken towel hook on drywall: 步骤 8 中的图像 1,1
    • With your screwdriver, continue screwing the screws in until they're flush with the towel hook.
    询问修复机器人
    添加评论
  9. How to replace a broken towel hook on drywall: 步骤 9 中的图像 1,1
    • Voila! Your new towel hook is installed!
    • But how about the hole we patched earlier?
    询问修复机器人
    添加评论
  10. How to replace a broken towel hook on drywall: 步骤 10 中的图像 1,2 How to replace a broken towel hook on drywall: 步骤 10 中的图像 2,2
    • Press the sandpaper against the wall and scrub on and around the hole, to level it with the wall.
    • After doing that for a few seconds, your patch should be leveled and your problem, solved!
    询问修复机器人
    添加评论
结论
This guide shows both removing the old, broken towel hook and installing the new towel hook! Hope it helped!
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 85
总计 2,854
