简介
Microsoldering technique for replacing a faulty IC to restore touch functionality in the iPhone 6.
你所需要的
In this tutorial you will learn how to resolve hardware touch issue in an iPhone 6 smartphone. In case of any troubles contac me through the comments.
12等其他人完成本指南。
8条评论
Do you change that ic with new one?
thanks before
aqsha asri - 回复
No, I have desoldered the proper chip from the other motherboard. Thanks for your interest and best luck with the repair!
Is it a good idea to change the whole screen
You are right, but sometimes it won’t work. Especially when it is a hardware issue.
? the logic board is not attached to the screen ... it has nothing to do with the screen, it is that - processor where one of the soldering points is not making contact and the tutorial shows just reheating to the point the soldering melts again and the crack or whatever that makes the connexion is broken gets fixed again, right?
queria o esquema eletrico do iphone 6 G, pois tenho 7 trilhas rompidas e preciso saber como ajeitar!! vcs tem o esquema?
se tiver pfv entre em contato… gmail; rafaelamorais012@gmail.com
Please translate your comment to english, thanks :-)
hey guys , i have an iphone 6 , my issue is a bit complicated. my iphone screen works like 70 percent of the screen . the screen left side doest respond to touch . i have changed displays but the same issue remains
Nothing about the M1 jumper… some details really lacking.
Mike Moran - 回复
I love how Eastern European people don't just throw away malfunctioning items, but instead repair them properly.
pat - 回复
