简介
Knitted beanies or pullovers are easy to snag during use, resulting in a loose thread loop. But it's not serious, and not hard to fix - follow this guide to find out how!
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
你所需要的
Identify the snag
Prepare your needle - for this guide we are using a specialized "snag repair needle" which has a textured end. These are available from most sewing shops.
Pass the needle through the bottom of the snag loop.
Wrap the thread around the sharp end of the needle.
Then, pass the needle through the fabric. The snag loop will also be pulled through by the textured part of the needle. Keep pulling it through, until both the needle and the snag loop are on the inside of the item.
Pull tightly on the thread to secure it to the back of the fabric.
Then, reposition the fabric appearance on the front, by stretching it to balance the tension.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
- Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
- Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
- Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
另外一个人完成了本指南。
