跳转到主内容
How to repair an iPhone that won't charge - Tristar Replacement
你所需要的
  1. How to repair an iPhone that won't charge - Tristar Replacement, Check for a new charger: 步骤 1 中的图像 1,1
    • Your cable could be bad, try a new one, possibly MFI certified ! (Made For iPhone) Or try a known-good one.
    • Try a new charging brick, or a known-good one that delivers at least 5V-1A
  2. How to repair an iPhone that won't charge - Tristar Replacement, Checking the charging port: 步骤 2 中的图像 1,1
    • Check your charging port, it could be really dirty or obstructed
    • If it looks dirty, you can take the risk to insert a thin tool and try to pry out the dirt. I am not responsible for the harm you could do to your phone !
  3. How to repair an iPhone that won't charge - Tristar Replacement, Try known-good internals: 步骤 3 中的图像 1,1
    • Try a known-good battery. Replace it if your phone charges again.
    • Try a known-good Lightning charging port. Replace it if your phone charges again.
    • I know, this is a picture of an iPhone 7, check the video for the 6S on the next step.
    • The whole french version of the process, video does help if you are an english-speaker !
  4. How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: 步骤 5 中的图像 1,2 How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: 步骤 5 中的图像 2,2
    • If you are still reading, bad news, you probably have a motheboard problem !
    • It's probably U4500, or Tristar that's causing it, it fails very frequently on iPhones. You'll have to replace it.
    • Video tutorial for Tristar replacement on iPhone 6S
结论
12等其他人完成本指南。
Alexandre Isaac
于04/07/13注册
2,863 声望
创作了8篇指南
团队
The Repair Academy The Repair Academy 的会员
Business
1 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 24
过去 30 天: 91
总计 10,804
