跳转到主内容
How to repair a trouser/cuff hem (by shortening)
你所需要的
  1. How to repair a trouser/cuff hem (by shortening), Defective hem: 步骤 1 中的图像 1,3 How to repair a trouser/cuff hem (by shortening), Defective hem: 步骤 1 中的图像 2,3 How to repair a trouser/cuff hem (by shortening), Defective hem: 步骤 1 中的图像 3,3
    • Identify the defective area and assess how large the damage is.
  2. How to repair a trouser/cuff hem (by shortening), Prepare the hem: 步骤 2 中的图像 1,3 How to repair a trouser/cuff hem (by shortening), Prepare the hem: 步骤 2 中的图像 2,3 How to repair a trouser/cuff hem (by shortening), Prepare the hem: 步骤 2 中的图像 3,3
    • Use a "seam ripper" tool to unstitch the original hem.
    • Unfold the hem.
    • Draw line above the defective part that you want to remove.
  3. How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 步骤 3 中的图像 1,3 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 步骤 3 中的图像 2,3 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: 步骤 3 中的图像 3,3
    • Cut along the line and set the removed piece aside.
    • Turn the item inside-out.
  4. How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 步骤 4 中的图像 1,3 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 步骤 4 中的图像 2,3 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: 步骤 4 中的图像 3,3
    • Draw a 1st line 2 cm from the edge - and a 2nd line with 2cm on top of it.
    • Fold the new hem twice on those lines.
  5. How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 步骤 5 中的图像 1,3 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 步骤 5 中的图像 2,3 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: 步骤 5 中的图像 3,3
    • Set up the iron on moderate heat without stream
    • Fixed the folded hem by ironing and then with pins.
  6. How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 步骤 6 中的图像 1,3 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 步骤 6 中的图像 2,3 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: 步骤 6 中的图像 3,3
    • Use a sewing machine to fix the hem.
    • Stitch 2mm from the edge and add a locking stitch at both ends.
    • Stitch the 2nd line parallel with the first.
    • Cut the extra thread to make a clean finished seam. Turn the item right-way-round.
  7. How to repair a trouser/cuff hem (by shortening), Finished and ready!: 步骤 7 中的图像 1,3 How to repair a trouser/cuff hem (by shortening), Finished and ready!: 步骤 7 中的图像 2,3 How to repair a trouser/cuff hem (by shortening), Finished and ready!: 步骤 7 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 394
