跳转到主内容
How to repair a hook & loop fastening
你所需要的
  1. How to repair a hook & loop fastening, Identify the defect: 步骤 1 中的图像 1,3 How to repair a hook & loop fastening, Identify the defect: 步骤 1 中的图像 2,3 How to repair a hook & loop fastening, Identify the defect: 步骤 1 中的图像 3,3
    • Check the defective area, and assess how big the repair will need to be.
    • Is the hook & loop part still mostly held in place with the original stitching? If so (like our example) then only a small repair is needed.
  2. How to repair a hook & loop fastening, Prepare & repair: 步骤 2 中的图像 1,3 How to repair a hook & loop fastening, Prepare & repair: 步骤 2 中的图像 2,3 How to repair a hook & loop fastening, Prepare & repair: 步骤 2 中的图像 3,3
    • Cut away any damaged thread around the defect, to provide a clean base for the repair.
    • Then, position the item under the sewing machine, and make a small locking stitch with the forward & reverse function.
    • Tip: use the iFixit basic sewing resources for more help on sewing machine setup.
    • Continue sewing around the defective zone, following the line of the original thread.
  3. How to repair a hook & loop fastening, Finished and ready!: 步骤 3 中的图像 1,3 How to repair a hook & loop fastening, Finished and ready!: 步骤 3 中的图像 2,3 How to repair a hook & loop fastening, Finished and ready!: 步骤 3 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • Note: we have used a contrast thread and a basic sewing pattern to demonstrate this repair. Bu you can have fun with bright colours, or interesting stitch patterns to further embellish your repair.
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
团队
INTERSPORT INTERSPORT 的会员
Community
25 名成员
创作了169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 50
总计 684
