跳转到主内容
How to repair a hole in a crochet dishcloth
你所需要的
  1. How to repair a hole in a crochet dishcloth, How to repair a hole in a crochet dishcloth: 步骤 1 中的图像 1,1
    • Collect the tools and materials you'll need.
  2. How to repair a hole in a crochet dishcloth: 步骤 2 中的图像 1,3 How to repair a hole in a crochet dishcloth: 步骤 2 中的图像 2,3 How to repair a hole in a crochet dishcloth: 步骤 2 中的图像 3,3
    • Identify any loose loops that may come undone if any yarn is pulled.
    • Put a safety pin through the loops, this will prevent the hole from getting any bigger.
  3. How to repair a hole in a crochet dishcloth: 步骤 3 中的图像 1,3 How to repair a hole in a crochet dishcloth: 步骤 3 中的图像 2,3 How to repair a hole in a crochet dishcloth: 步骤 3 中的图像 3,3
    • Pick one of the loose strands and tie the yarn to this strand.
    • Make three knots to ensure the knot will not come undone.
  4. How to repair a hole in a crochet dishcloth: 步骤 4 中的图像 1,3 How to repair a hole in a crochet dishcloth: 步骤 4 中的图像 2,3 How to repair a hole in a crochet dishcloth: 步骤 4 中的图像 3,3
    • Begin your first stitch by pushing the crochet hook through the stitch closest to the tied on yarn.
    • Next, wrap the yarn in front of the hook and pull it through the stitch making sure the hook catches the yarn.
  5. How to repair a hole in a crochet dishcloth: 步骤 5 中的图像 1,3 How to repair a hole in a crochet dishcloth: 步骤 5 中的图像 2,3 How to repair a hole in a crochet dishcloth: 步骤 5 中的图像 3,3
    • Continuing on your first stitch, wrap the yarn in front of the hook and pull it in the direction of the arrow through the loop wrapped around the crochet hook.
    • Move on to the next stitch where the orange arrow is pointing. Continue making stitches around the hole until there is a small opening.
  6. How to repair a hole in a crochet dishcloth: 步骤 6 中的图像 1,3 How to repair a hole in a crochet dishcloth: 步骤 6 中的图像 2,3 How to repair a hole in a crochet dishcloth: 步骤 6 中的图像 3,3
    • Once you have a small opening you will now close the hole. Using the same stitch used throughout the guide, make a stitch interlocking every other stitch.
    • The crochet hook should be moving in the direction the arrow is pointing.
  7. How to repair a hole in a crochet dishcloth: 步骤 7 中的图像 1,3 How to repair a hole in a crochet dishcloth: 步骤 7 中的图像 2,3 How to repair a hole in a crochet dishcloth: 步骤 7 中的图像 3,3
    • Continuing until the hole is completely closed.
    • Cut the yarn leaving about a 4 inch tail.
    • Pull the loop in the direction the arrow is pointing.
  8. How to repair a hole in a crochet dishcloth: 步骤 8 中的图像 1,3 How to repair a hole in a crochet dishcloth: 步骤 8 中的图像 2,3 How to repair a hole in a crochet dishcloth: 步骤 8 中的图像 3,3
    • Using the large threading needle, thread in all of the strands of yarn.
结论
Rayme Ivers
于05/04/20注册
157 声望
撰写一个指南
团队
UW Tacoma, Team S1-G8, Cardinal Spring 2020 UW Tacoma, Team S1-G8, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G8
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 2,870
