简介
Small tags on gloves, hats, and other accessories are easy to snap off by mistake - especially on kids items. But they're simple to fix back on, with the help of a sewing machine.
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
你所需要的
Often the cause of the breakage, is that the sewing thread tore through the tag, leaving frayed ends
Trim away any damaged or frayed ends of the tag
Use a "seam ripper" tool, or small scissors, to carefully remove the old thread from the item
Prepare your sewing machine in a clean location, and position the item underneath the needle. Depress the foot to secure the item in place.
Tip: for setting up a sewing machine, use the resource Thread a Sewing Machine
Make a short lock stitch, and then a straight line stitch from one side of the label to the other. Make a second stitch using the reverse lever, and one final stitch in the original direction. Finish with a locking stitch
Remove the item from the machine.
Carefully trim the thread on the outside...
... and on the inside
Check the repair and pull the label gently to test the durability
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
- Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
- Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
- Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
