跳转到主内容
How to repair a IdeaPad with faulty fingerprint
你所需要的
  1. How to repair a IdeaPad with faulty fingerprint, Back Panel: 步骤 1 中的图像 1,2 How to repair a IdeaPad with faulty fingerprint, Back Panel: 步骤 1 中的图像 2,2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. How to repair a IdeaPad with faulty fingerprint: 步骤 2 中的图像 1,3 How to repair a IdeaPad with faulty fingerprint: 步骤 2 中的图像 2,3 How to repair a IdeaPad with faulty fingerprint: 步骤 2 中的图像 3,3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. How to repair a IdeaPad with faulty fingerprint: 步骤 3 中的图像 1,2 How to repair a IdeaPad with faulty fingerprint: 步骤 3 中的图像 2,2
    • Once all the clips have been disengaged, lift off the back cover.
  4. How to repair a IdeaPad with faulty fingerprint, Battery: 步骤 4 中的图像 1,2 How to repair a IdeaPad with faulty fingerprint, Battery: 步骤 4 中的图像 2,2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. How to repair a IdeaPad with faulty fingerprint: 步骤 5 中的图像 1,3 How to repair a IdeaPad with faulty fingerprint: 步骤 5 中的图像 2,3 How to repair a IdeaPad with faulty fingerprint: 步骤 5 中的图像 3,3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
结论
[deleted]
于02/07/19注册
221 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24
