简介
Use this guide to analyze and repair AC leaks.
AC system leaks occur most frequently when one or more components malfunction. It's possible that one of your system's drain pans is cracked, or that your air filter or drain line is clogged, or AC sputters. These problems may lead to refrigerant leaks that impair the functionality of your system and reduce its effectiveness. Long-term issues that could arise if you don't repair your leaky AC unit include:
- A costly AC system repair bill
- Higher energy bills and increased energy use
- Exposure to substances that can harm your lungs and cause burns
- Damaging emissions that could harm the environment
With this guide you will be taken on a step by step procedure on how to safely and easily asses and repair any and all problems that your AC may have.
Be advised!, if after a complete DIY diagnosis of your AC, if problem turns out to be a refrigerant leak, refrain from fixing on your own. Highly recommended to consult professional help to avoid costly mistakes.
你所需要的
Check the drain pan for cracks or rust. If any are visible, using an epoxy putty on the small holes can be then patched. If the damage is severe then the pan will need to be replaced.
For reassembly, just reverse disassembly steps.
另外一个人完成了本指南。
