跳转到主内容
How to remove top vent of Winix C535
你所需要的
  1. How to remove top vent of Winix C535, Locating the tabs: 步骤 1 中的图像 1,1
    • I suggest starting from the middle, popping it out just a tiny bit and move outwards to the sides
    • Apply a small constant lift should make removing this easier. Similar to disassembling other plastic encasements.
  2. How to remove top vent of Winix C535, Taking it out: 步骤 2 中的图像 1,2 How to remove top vent of Winix C535, Taking it out: 步骤 2 中的图像 2,2
    • It pulls towards you a little bit to loosen up and then comes out by moving it forward once it's in this position.
    • Clean the vent and reassemble by inserting it from the bottom first and then clicking in the tabs in the front.
  3. How to remove top vent of Winix C535, Done: 步骤 3 中的图像 1,1
    • Well that was easy wasn't it? Back to making it eat wildfire smoke and whatnot when the time comes.
    • Also do keep in mind that "PlasmaWave" is an ionizing tech which creates ozone in small amounts (regardless of what manufacturer says), so don't use it that often. If you do, you need to air out the room/house when the outside air is cleaner.
结论
另外一个人完成了本指南。
Ray
于01/21/21注册
127 声望
撰写一个指南
1指南评论
thank you very much
Thusy Veeram - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 52
总计 2,106
