跳转到主内容
How to remove the Samsung LA40R81BD 40in LCD TV rear cover
你所需要的
  1. How to remove the Samsung LA40R81BD 40in LCD TV rear cover, Rear Cover: 步骤 1 中的图像 1,1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
结论
11等其他人完成本指南。
Richdave
于04/09/10注册
32,287 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
3条评论
Got cover off but how to unplug the wires
cpeeledc - 回复
What size screws holds on the rear panel?
D Mack Miller - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 40
总计 24,260
