跳转到主内容
加入维修社区 - 创建账户
How to remove the 2010-2017 Suzuki Swift front bumper
你所需要的
  1. How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 步骤 1 中的图像 1,3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 步骤 1 中的图像 2,3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the top fasteners: 步骤 1 中的图像 3,3
    • Open the hood and unscrew the 10mm bolts located at the top.
    • Unscrew the screw located at the side top corner under the fender, repeat on the other side.
  2. How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 步骤 2 中的图像 1,3 How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 步骤 2 中的图像 2,3 How to remove the 2010-2017 Suzuki Swift front bumper, remove bottom fasteners: 步骤 2 中的图像 3,3
    • Unscrew 4 screws located underneath the front of the front bumper.
    • With the flathead, unclip the 2 push rivets underneath the side of the front bumper, disconnecting each fender from the bumper.
    • Repeat on the other side.
  3. How to remove the 2010-2017 Suzuki Swift front bumper, detach top corners: 步骤 3 中的图像 1,2 How to remove the 2010-2017 Suzuki Swift front bumper, detach top corners: 步骤 3 中的图像 2,2
    • Gently, pull the side corner loose.
    • Pull from the car and slightly downwards to detach the remaining corner.
  4. How to remove the 2010-2017 Suzuki Swift front bumper, unlatch the bumper: 步骤 4 中的图像 1,2 How to remove the 2010-2017 Suzuki Swift front bumper, unlatch the bumper: 步骤 4 中的图像 2,2
    • If your car has fog lights, make sure you disconnect them from the car's wiring.
    • The bumper is now only attached with 2 clips at the top.
    • Push the front of each clip towards the car and unlatch it.
  5. How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 步骤 5 中的图像 1,3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 步骤 5 中的图像 2,3 How to remove the 2010-2017 Suzuki Swift front bumper, remove the bumper: 步骤 5 中的图像 3,3
    • Hold the bumper in the center and remove it by moving it down and outwards.
    • The bumper wraps around the bottom and fender parts, take care not to damage anything when removing the bumper.
    • Some of the 4 bottom nut clips might move or detach entirely when removing the bumper. Ensure these are at their correct positions.
结论
2等其他人完成本指南。
knipwim
于09/01/18注册
14,906 声望
创作了42篇指南
3指南评论
In mine there were also two screws at the corners featured in step 3 that needed removing.
Thomas Bell - 回复 分享
Other screws than you need to remove in step 1 photo 2/3?
knipwim - 分享
Followoing your instruction on Step 3. I break 3 small clips that attach the bumper on the side. Now without the 3 clips, my bumper looks a bit overhang from the side
Mr Ismail Harun - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 38
过去 30 天: 188
总计 9,893
