跳转到主内容
How to remove the 2010-2017 Suzuki Swift air intake box
你所需要的
  1. How to remove the 2010-2017 Suzuki Swift air intake box, Loosen the air intake box: 步骤 1 中的图像 1,3 How to remove the 2010-2017 Suzuki Swift air intake box, Loosen the air intake box: 步骤 1 中的图像 2,3 How to remove the 2010-2017 Suzuki Swift air intake box, Loosen the air intake box: 步骤 1 中的图像 3,3
    • Unscrew the 10mm bolts.
    • Remove the push rivet with the flathead.
    • Unclip the cable from the bracket. Use the plyers to press the lock from beneath and pull the clip loose.
    • Pull back the clasps connecting the air intake box to the rest of the intake system.
  2. How to remove the 2010-2017 Suzuki Swift air intake box, Remove the air intake box: 步骤 2 中的图像 1,3 How to remove the 2010-2017 Suzuki Swift air intake box, Remove the air intake box: 步骤 2 中的图像 2,3 How to remove the 2010-2017 Suzuki Swift air intake box, Remove the air intake box: 步骤 2 中的图像 3,3
    • Grab the box at the left side and pull up and towards the right to pull the top part of air intake box out.
    • Pull the intake pipe up and out.
结论
To reassemble, follow these instructions in reverse order.
knipwim
于09/01/18注册
8,527 声望
创作了30篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 42
过去 30 天: 116
总计 2,140
