跳转到主内容
修复你的物品
维修的权力
商店
简介
If your Arbor Rally longboard has felt sluggish recently or you're not satisfied with it's performance, this guide will help you improve your ride.
配件
  1. Use the half inch wrench to remove the nut on each wheel. Then remove each wheel. Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
    • Use the half inch wrench to remove the nut on each wheel. Then remove each wheel.
    • Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
  2. Use needle nose pliers to remove the bearings from both sides of each wheel. Use needle nose pliers to remove the bearings from both sides of each wheel. Use needle nose pliers to remove the bearings from both sides of each wheel.
    • Use needle nose pliers to remove the bearings from both sides of each wheel.
  3. Place the bearings in soapy water and let them soak for 5 minutes. Place the bearings in soapy water and let them soak for 5 minutes.
    • Place the bearings in soapy water and let them soak for 5 minutes.
  4. Wipe off the dirt from each bearing and dry them thoroughly with a paper towel. Wipe off the dirt from each bearing and dry them thoroughly with a paper towel. Wipe off the dirt from each bearing and dry them thoroughly with a paper towel.
    • Wipe off the dirt from each bearing and dry them thoroughly with a paper towel.
  5. Apply a few drops of lubricant to the inner portion on both sides of each bearing. Spin the bearings and wipe off any extra lubricant that has not settled in.
    • Apply a few drops of lubricant to the inner portion on both sides of each bearing.
    • Spin the bearings and wipe off any extra lubricant that has not settled in.
  6. Push the bearing into the wheel by applying even pressure with your thumb. Push the bearing into the wheel by applying even pressure with your thumb. Push the bearing into the wheel by applying even pressure with your thumb.
    • Push the bearing into the wheel by applying even pressure with your thumb.
  7. Spin the wheel to make sure that the bearings are properly aligned and running smoothly. Spin the wheel to make sure that the bearings are properly aligned and running smoothly. Spin the wheel to make sure that the bearings are properly aligned and running smoothly.
    • Spin the wheel to make sure that the bearings are properly aligned and running smoothly.
  8. Place the wheel on the axle followed by washer and then the nut. Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job. Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
    • Place the wheel on the axle followed by washer and then the nut.
    • Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job.
    • Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
结论
4等其他人完成本指南。
Casey Barbello
于2013年07月24日注册
187 信誉积分
撰写一个指南
团队
Great guide! I was trying to figure out how to pop the bearings out - the needle nose pliers did a great job.
jewbot007 - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 15
过去的30天: 54
总计 10,805
