跳转到主内容
加入维修社区 - 创建账户
How to remove a stuck bike seat post without destroying the post
你所需要的
视频概述
    1. How to remove a stuck bike seat post without destroying the post, How to remove a stuck bike seat post without destroying the post: 步骤 1 中的图像 1,1
      • For Tools you will need a saw, socket set, drill, wire brush drill bit that inside the post sleeve and a long drill bit extension.
      • For parts you will need about a foot of stout chain, two quick links, 1/4" #8 steel bolt/washers/nut long enough to go through the seat post, two 1/4" steel bolts/washers/nuts at least 5 1/2" long to hold the 2x4s together at the base and a huge eye bolt and a 8' 2x4 stud. all can be bought at your local hardware store.
      • Look for a rating of at least 1000lb in all the parts you buy. they are low cost and that way you don't need to worry about things snapping.
      询问修复机器人
      添加评论
      • cut a 5" section of 2x4 and drill a hole in the middle for the eye bolt.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Gabe
于01/28/15注册
318 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 70
总计 3,261
