本指南有最近更改,您可查看未经巡查的最新版本。
简介
Before starting this guide there are some things you should be aware of; First make sure your vehicle is parked on a level surface with the parking brake on. This is needed for one step so you can safely put the vehicle in 1st gear so the shifter is out of the way. For this tutorial the only tools needed are 1/4" ratchet, 16mm wrench, and 7 mm wrench .
你所需要的
Locate the hood latch in your vehicle located on the drivers side under the dash to the left of the parking brake pedal.
Pull the latch to release hood.
This is the back panel of the head unit and assorted wiring connections that you can now access for upgrades, replacements, or fixes.
Listed below are the wires coming connected to the head unit. The colors correspond to the same color of the wire.
RCA inputs
Microphone input/wire
Power/audio/assorted control wire harness
Antenna input/wire
Harness disconnect
9等其他人完成本指南。
