跳转到主内容
How to remove FHX-720bt head unit in a 1999-2007 Chevrolet Silverado
你所需要的
  1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 1 中的图像 1,2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 1 中的图像 2,2
    • Locate the hood latch in your vehicle found on the drivers side under the dashboard to the left of the parking brake pedal.
    • Pull the latch to release hood.
  2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 2 中的图像 1,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 2 中的图像 2,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 2 中的图像 3,3
    • Locate the release latch for the hood in between the grille and hood, directly above the "GMC" logo at the front of the car.
    • Lift up on the latch then raise the hood.
  3. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 3 中的图像 1,2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 3 中的图像 2,2
    • Locate your battery in the front of the engine compartment near the headlight, on the driver's side.
    • Remove the black negative terminal with 5/16" socket or by using a 5/16" wrench.
    • BE CAREFUL. DO NOT CROSS POSITIVE AND NEGATIVE WIRES.
  4. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 4 中的图像 1,2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 4 中的图像 2,2
    • Make sure the vehicle is on a flat surface, then use the parking brake.
    • Shift vehicle into 1st gear so the shifter will be out of the way for the next step.
  5. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 5 中的图像 1,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 5 中的图像 2,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 5 中的图像 3,3
    • Firmly grasp the top of the dash trim and pull it towards you.
    • Once it is removed from its clips, pull up and the trim will come out the rest of the way.
    • Set the trim aside; you are ready for the next step.
  6. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 6 中的图像 1,2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 6 中的图像 2,2
    • Remove the face plate from the head unit.
    • To do this, pull out on both the left and right sides to release the face plate from its clips.
    • After being released from the clips, set the face plate aside and continue to the next step.
  7. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 7 中的图像 1,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 7 中的图像 2,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 7 中的图像 3,3
    • Remove three bolts using a 7mm socket wrench, two on the left and one on the right.
  8. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 8 中的图像 1,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 8 中的图像 2,3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 8 中的图像 3,3
    • Remove the head unit once the bolts have been taken out.
  9. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 9 中的图像 1,2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: 步骤 9 中的图像 2,2
    • Place the head unit face down to allow the wires on the back to be visible and more easily accessible.
    • Listed below are the wires coming connected to the head unit. The colors correspond to the same color of the wire.
    • RCA inputs
    • Microphone input/wire
    • Power/audio/assorted control wire harness
    • Antenna input/wire
    • Harness disconnect
结论
9等其他人完成本指南。
Justin Reiner
于09/29/15注册
317 声望
撰写一个指南
团队
Cal Poly, Team 15-1, Green Fall 2015 Cal Poly, Team 15-1, Green Fall 2015 的会员
CPSU-GREEN-F15S15G1
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 37
总计 1,850
