跳转到主内容
How to refurbish performance skateboard bearings
你所需要的
  1. How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: 步骤 1 中的图像 1,2 How to refurbish performance skateboard bearings, How to refurbish performance skateboard bearings: 步骤 1 中的图像 2,2
    • Turn your wrench to the left to remove the wheel nut.
    • Take the wheel off of your trucks by pulling.
    • Keep all nuts and spacers in separated, designated areas.
    • Wear gloves. You are working with messy materials such as gasoline.
  2. How to refurbish performance skateboard bearings: 步骤 2 中的图像 1,2 How to refurbish performance skateboard bearings: 步骤 2 中的图像 2,2
    • Firmly lever the bearing out using your screwdriver.
    • Do not be overly forceful to avoid scratching the bearing.
  3. How to refurbish performance skateboard bearings: 步骤 3 中的图像 1,1
    • Soak the bearing in a cup with premium gasoline for 5 minutes.
    • Soak each bearing separately so none are lost or dented.
  4. How to refurbish performance skateboard bearings: 步骤 4 中的图像 1,3 How to refurbish performance skateboard bearings: 步骤 4 中的图像 2,3 How to refurbish performance skateboard bearings: 步骤 4 中的图像 3,3
    • Take the bearing out of the gasoline and remove one side of the outside plastic locks by applying pressure on the inner ring and prying up.
    • Make sure you can clearly see and access the ball bearings.
  5. How to refurbish performance skateboard bearings: 步骤 5 中的图像 1,1
    • Use your toothbrush to clean the bearings by using a gentle back and forth scrubbing motion.
    • Rinse the bearing with water and let dry for 5 minutes.
  6. How to refurbish performance skateboard bearings: 步骤 6 中的图像 1,2 How to refurbish performance skateboard bearings: 步骤 6 中的图像 2,2
    • Once dry, pick up your bearings with two fingers and drop 2 drops of skateboard lubricant into the bearing.
    • Spin the bearings immediately to spread the lubricant evenly.
  7. How to refurbish performance skateboard bearings: 步骤 7 中的图像 1,3 How to refurbish performance skateboard bearings: 步骤 7 中的图像 2,3 How to refurbish performance skateboard bearings: 步骤 7 中的图像 3,3
    • Use a paper towel to remove excess lubricant.
    • Replace the plastic guard.
结论
To reassemble your device, firmly put bearings back into your wheels and tighten them back down onto the trucks.
另外一个人完成了本指南。
Luke Marshall
于04/09/15注册
126 声望
撰写一个指南
团队
Cal Poly, Team 30-2, Green Spring 2015 Cal Poly, Team 30-2, Green Spring 2015 的会员
CPSU-GREEN-S15S30G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 5,869
