跳转到主内容
How to recover accidentally removed data from NAS
你所需要的
  1. How to recover accidentally removed data from NAS, How to recover accidentally removed data from NAS: 步骤 1 中的图像 1,1
    • Take the disks out of the NAS device and connect them to a Windows computer.
  2. How to recover accidentally removed data from NAS, To initialize or format?: 步骤 2 中的图像 1,1
    • If the operating system of the computer to which you have connected the disks asks you to initialize or format them, don’t do that, because it will make recovery a lot more complicated.
  3. How to recover accidentally removed data from NAS: 步骤 3 中的图像 1,1
    • Run Hetman RAID Recovery. It will analyze the disks, read their service information and rebuild the damaged RAID system. Below, you can see detailed information about the array and check if the program has identified it correctly.
  4. How to recover accidentally removed data from NAS, Start a scan: 步骤 4 中的图像 1,3 How to recover accidentally removed data from NAS, Start a scan: 步骤 4 中的图像 2,3 How to recover accidentally removed data from NAS, Start a scan: 步骤 4 中的图像 3,3
    • To start a scan, right-click on the disk and choose “Open”. Select the scan type and click Next to start it.
  5. How to recover accidentally removed data from NAS, The program has rebuilt the damaged RAID: 步骤 5 中的图像 1,1
    • As you can see, the program has rebuilt the damaged RAID easily and found all the files stored on the network drive. If you are looking for files that have been removed, you can identify them by red crosses.
  6. How to recover accidentally removed data from NAS, Select all the items you want to recover: 步骤 6 中的图像 1,2 How to recover accidentally removed data from NAS, Select all the items you want to recover: 步骤 6 中的图像 2,2
    • Select all the items you want to recover, click Recovery, select where you want to save them. When the recovery process is over, you’ll find all of the files in the folder you have chosen.
  7. How to recover accidentally removed data from NAS, How to recover data from an iSCSI disk: 步骤 7 中的图像 1,2 How to recover accidentally removed data from NAS, How to recover data from an iSCSI disk: 步骤 7 中的图像 2,2
    • If files are deleted accidentally from an iSCSI disk, you don’t have to take the hard disks out of the NAS device and connect them to a computer – just run our program and scan the network drive.
  8. How to recover accidentally removed data from NAS, How to rebuild a damaged array manually with the RAID Constructor: 步骤 8 中的图像 1,1
    • When a disk is damaged or service information is erased, the program may have difficulty in automating the rebuild process. If the program failed to rebuild the array but you know its properties, you can perform this operation manually, with the help of the RAID Constructor.
结论
2等其他人完成本指南。
1指南评论
If you have any questions about recovering data from NAS, leave a comment to ask.
Denver Dela Cruz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 268
