本指南有最近更改,您可查看未经巡查的最新版本。
简介
If you have problems with your chromebook, use this to get into recovery mode to restore your chromebook or to get into dev mode.
你所需要的
This is JAShadic bringing you a step-by-step guide on how to enable recovery mode on your Samsung ARM Chromebook.
Step 1: Backup any data on the hard drive since this will be wiped out when you decide to get a fresh Chrome OS.
Step 2: Once that's completed, you will need the use of 3 fingers: One to hold escape, one to hold the refresh button, and one to poke the power button.
If done correctly, your Chromebook will reset and have a screen that will tell you that you're in recovery mode.
From here, you can enter dev mode or restore to a new Chrome OS.
35等其他人完成本指南。
9条评论
what can be the problem if there is an error message? freakin ukranian took my laptop away didnt know what he was doing charged me 2000rubles just for the nerves and travelling an hour to him to collect the computer with the same $@$*. i followed all the troubleshoots on the chrome os recovery site. is it idiotic to get a new mother straight away?
Same here....
I did everything the internet says to do to fix this on my Chromebook and it still says the same thing and hasn't changed. But I noticed that if I click ctrl+alt+ shift+R it will change the tab recovery_reason to 0×05 TPM error in read-only firmware and then if I click ESC+ refresh+power button, the tab recovery reason goes back to 0×02 recovery button pressed. So I'm very confused. The screen when I turn it on is a white background that has a giant yellow exclamation mark with words under it saying Chrome OS is missing or damaged. Please insert a recovery USB stick or SD card. (note: the blue USB port will NOT work for recovery) I brought it to the store I bought it from but they literally didn't care or help me in anyway and they sent me away
same problem. Did you find a way to fix this?
