简介
This guide is for pulling data off a Solnist Levelogger that has been deployed in the field.
你所需要的
Only compatible with Windows, you may need to install new drivers for the USB connection
Under the cap there are three holes- two of those holes are for optical communication, one hole is for the pin on the optical reader. Connect the reader so that the metal pin fits in the correct hole and you can tightly screw the logger to the reader.
The boxed red fields are the only ones you should need to fill in.
终点
另外一个人完成了本指南。
