跳转到主内容
How to re-caulk a bathroom sink
你所需要的
  1. How to re-caulk a bathroom sink, Caulk seal: 步骤 1 中的图像 1,1
    • Clean and dry around the rim of the sink with a paper towel.
    • Make sure the old caulk is completely dry before moving on.
  2. How to re-caulk a bathroom sink: 步骤 2 中的图像 1,1
    • Remove the old caulk around the rim of the sink with a utility knife.
  3. How to re-caulk a bathroom sink: 步骤 3 中的图像 1,1
    • Remove any old caulk residue around the rim of the sink with a wet paper towel.
    • Then dry the area completely.
    • Ensure the area is completely clean and dry before applying the new caulk.
  4. How to re-caulk a bathroom sink: 步骤 4 中的图像 1,3 How to re-caulk a bathroom sink: 步骤 4 中的图像 2,3 How to re-caulk a bathroom sink: 步骤 4 中的图像 3,3
    • Apply painter's tape around the rim of the sink while leaving a small gap for caulk to be applied.
  5. How to re-caulk a bathroom sink: 步骤 5 中的图像 1,2 How to re-caulk a bathroom sink: 步骤 5 中的图像 2,2
    • Place the caulk tube into the gun.
    • Slowly press the trigger to release a thin line of caulk and move around the edge of the sink as you go.
  6. How to re-caulk a bathroom sink: 步骤 6 中的图像 1,3 How to re-caulk a bathroom sink: 步骤 6 中的图像 2,3 How to re-caulk a bathroom sink: 步骤 6 中的图像 3,3
    • Smooth out the caulk against the edge of the rim and counter with your wet index finger.
    • Keep a rag nearby to wipe excess caulk from your finger periodically.
    • Press against the caulk firmly while sliding your index finger as you go around the rim of the sink.
  7. How to re-caulk a bathroom sink: 步骤 7 中的图像 1,3 How to re-caulk a bathroom sink: 步骤 7 中的图像 2,3 How to re-caulk a bathroom sink: 步骤 7 中的图像 3,3
    • Pull the tape away from the counter immediately after applying the caulk.
    • Pulling away from the counter will help keep the caulk in a straight line.
  8. How to re-caulk a bathroom sink: 步骤 8 中的图像 1,1
    • Wipe off any excess caulk from the edge of the rim with a wet paper towel.
  9. How to re-caulk a bathroom sink: 步骤 9 中的图像 1,1
    • Let the new caulk dry for at least a day before using the sink.
终点
另外一个人完成了本指南。
Thi Nguyen
于04/29/20注册
201 声望
撰写一个指南
团队
UW Tacoma, Team S1-G43, Cardinal Spring 2020 UW Tacoma, Team S1-G43, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G43
1 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 41
过去 30 天: 191
总计 5,018
