跳转到主内容
How to properly install the flex cable on the 4th Generation Touch
  1. How to properly install the flex cable on the 4th Generation Touch, How to properly install the flex cable on the 4th Generation Touch: 步骤 1 中的图像 1,2 How to properly install the flex cable on the 4th Generation Touch, How to properly install the flex cable on the 4th Generation Touch: 步骤 1 中的图像 2,2
    • Esta es la forma correcta de doblar el cable flex de la pantalla.
    • English: This is the correct way to bend the flex cable to the display.
  2. How to properly install the flex cable on the 4th Generation Touch: 步骤 2 中的图像 1,1
    • No doblar el cable flex de esta forma.
    • English: Do not bend the flex cable this way.
  3. How to properly install the flex cable on the 4th Generation Touch: 步骤 3 中的图像 1,1
    • Al doblar el cable flex de forma incorrecta la pantalla no entra completamente en el socket y se quiebra al tratar de cerrar el iPod.
    • English: When bending the flex cable incorrectly the screen does not fit completely into the socket and breaks when trying to close the iPod.
结论
12等其他人完成本指南。
fibocellphone
于03/28/14注册
577 声望
撰写一个指南
一条评论
after replacing flex cable is not working so touch is not responding ,display is good ....how I can fix the touch.
Abhimanyu Raj - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 42
总计 7,212
