跳转到主内容
How to prep and clone SSD with MacOS Catalina
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. How to prep and clone SSD with MacOS Catalina, Prep: 步骤 1 中的图像 1,1
    • Hardware needed:
    • SSD of greater size than existing used data.
    • Sata SSD to USB adapter
    • Plug in the new SSD via the adapter
    • Ensure you have Catalina installed currently on your Mac
  2. How to prep and clone SSD with MacOS Catalina, Install Catalina on the New SSD: 步骤 3 中的图像 1,1
    • Boot to recovery by holding cmd + r immediately after the device boots up. Hold until you see the apple logo
    • Choose Reinstall macOS
    • BE SURE TO INSTALL TO THE NEW DRIVE
    • Do not reinstall to your existing drive
    • The reason to do this is to set up the file structure in the specific way that Catalina needs
  3. How to prep and clone SSD with MacOS Catalina, Disk Utility: 步骤 5 中的图像 1,1
    • Once the new SSD has catalina on it
    • Exit the setup menu, power off
    • Reboot to recovery mode using the same cmd + R method as before.
    • Use the top menu View>>Show All Devices
  4. How to prep and clone SSD with MacOS Catalina, Clone/Restore: 步骤 6 中的图像 1,1
    • Since there are two partitions this step will be done twice.
    • Select the new (currently external) SSD that has catalina on it. Select the first partition. I've called my disk MacGuyver
    • Then Click restore and choose the corresponding partition on your existing Catalina disk still installed in the computer
    • Once that is complete Repeat the recovery process for the second partition, this may have the word - Data on the end of the named disk.
    • This step is critical. The goal is to recover your data from the old drive to the new drive. Catalina uses two partitions, so the step must be done twice. This can take a while...
    • Once in recovery mode, choose disk utility.
    • At the top left find the option to set the boot disk. This should be the new SSD that you just installed
    • I actually ran first aid on each partition before doing this step. I'm not sure if this was necessary.
  5. How to prep and clone SSD with MacOS Catalina, Boot it UP!: 步骤 9 中的图像 1,1
    • Restart and it should boot like you never left.
    • Enter your password and login!
    • You can now use your old drive for a backup, time machine, or extra storage now that you have the adapter to use it!
结论
Enjoy the speeds of SSD!
另外一个人完成了本指南。
lucas
于11/30/16注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 201
