跳转到主内容
How to override the fast fan caused by an Incompatible Drive
你所需要的
  1. How to override the fast fan caused by an Incompatible Drive, How to override the fast fan caused by an Incompatible Drive: 步骤 1 中的图像 1,3 How to override the fast fan caused by an Incompatible Drive, How to override the fast fan caused by an Incompatible Drive: 步骤 1 中的图像 2,3 How to override the fast fan caused by an Incompatible Drive, How to override the fast fan caused by an Incompatible Drive: 步骤 1 中的图像 3,3
    • Pretty simple guide here . UNSCREW the logic board PCB from the ORIGINAL hard drive from the iMac 2009/2010/2011+ Hard dive for step 1:
  2. How to override the fast fan caused by an Incompatible Drive: 步骤 2 中的图像 1,3 How to override the fast fan caused by an Incompatible Drive: 步骤 2 中的图像 2,3 How to override the fast fan caused by an Incompatible Drive: 步骤 2 中的图像 3,3
    • Step 2: is simple. Simply put clear tape or anti static tape on the logic board PCB of the original hard from the iMac . Making sure it wont touch anything, as safety.
    • MAKE SURE YOU PLUG IN only the temperature sensor cable FROM the iMac to the hard drive Logic board we have taped to the iMacs back housing, this is *crucial. This will make the iMac control the fan speed as normal. :)
  3. How to override the fast fan caused by an Incompatible Drive: 步骤 3 中的图像 1,2 How to override the fast fan caused by an Incompatible Drive: 步骤 3 中的图像 2,2
    • and thats it !
    • install hard drive, there is just enough space. Enjoy
结论
8等其他人完成本指南。
codahyder
于06/28/15注册
257 声望
撰写一个指南
3条评论
Hi! So sorry about that. I did not put in the exact corresponding models which will work with this exact guide (only models WITH temp sensor cable apply* here). Thanks so much for checking it out! I made this a while back, sort of to keep what I had done in archive and to *possibly* help others. For one software fix* I have used a program for Mac called "SSD Fan Control" and it does wonders. For a permanent fix I am not so sure/ there may be kits available through some 3RD party mac stores . Possibly even here ?! That help reroute the internal temp sensor models. Again apologies and best of luck to anyone trying to figure this out. haha :)
Lost account - 回复
I use HDD Fan Control. It uses the temperature read by S.M.A.R.T in the replacement drive. http://www.hddfancontrol.com/
steve - 回复
Can somebody explain how the apple control system works exactly? Why is the above mentioned fix really safe?
Wulf Brandes - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 75
总计 8,835
