跳转到主内容
How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition
你所需要的
  1. How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition, How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition: 步骤 1 中的图像 1,1
    • Attach stroboscopic timing light to the battery
    • Negative (black) lead attaches first
    • Then attach the positive (red) lead
  2. How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition: 步骤 2 中的图像 1,1
    • Attach stroboscopic timing light's current sensor to the wire leading to Cylinder #1
    • You can identify the cylinder by the printed number.
    • The current sensor attaches around the wire leading out of the cylinder.
  3. How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition: 步骤 3 中的图像 1,1
    • Using a 9/16 inch wrench, loosen the distributor adjustment bolt and leave the wrench in place
  4. How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition: 步骤 4 中的图像 1,1
    • Start the engine
    • Remove the vacuum advance hose from the carburetor and plug it
    • You are now ready to begin reading the timing
  5. How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition: 步骤 5 中的图像 1,2 How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition: 步骤 5 中的图像 2,2
    • Point the timing light at the timing scale
    • The light will strobe when the cylinder fires and a mark on the crank shaft pulley will become visible.
    • The mark will appear next to the timing scale. The mark next to the timing scale indicates where the timing is currently set.
    • There are numbers on the scale, although they may be faded, and your timing value will likely be in between the marked values
    • The scale contains major marks at 0, 8, and 16 with minor marks at 4 and 12 Before Top Dead Center (BTDC)
    • All models will have differing timing values depending on the year and transmission.
    • Our model-year was 1965 which has an ideal timing value of 14 degrees BTDC (in between 12 and 16 marks)
    • For other model-years, consult the list of timing values provided here
  6. How to optimize the timing of your 1965-1969 Chevrolet Corvair ignition: 步骤 6 中的图像 1,1
    • Now that you know what your timing is currently set to, and you have looked up what it should be set at, you are ready to adjust the distributor to correct any differences.
    • Grab the distributor and, while watching the timing mark as explained previously, rotate it slowly to one side or the other. Continue rotating until the timing mark is in the correct position. Refer to step 4 for how to read the timing mark.
    • You must turn very slowly, otherwise you can go outside of the acceptable timing range and severely damage your engine.
    • Carefully tighten the 9/16 locking bolt, and remove the wrench, making sure not to accidently rotate the distributor or contact the spinning pulley and belt.
结论
Your timing is now set correctly! To finish, simply shut off the engine, reconnect the vacuum advance hose, and disconnect the stroboscopic timing light. If you have points, the timing should be checked and set every few thousand miles. Replacing your original points unit with an electronic ignition has many benefits, such as nearly entirely eliminating the need to re-time your ignition!
11等其他人完成本指南。
Mackey Hopen
于10/04/12注册
409 声望
撰写一个指南
团队
Cal Poly, Team 6-33, Regan Fall 2012 Cal Poly, Team 6-33, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G33
3 名成员
创作了7篇指南
一条评论
I want the pdf file for this engine timing.
Augustine Ragi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 72
总计 30,426
